Mitsubishi Motors Corporation (MMC) and Mitsubishi Motors North America Inc. (MMNA, based in Cypress California) will premiere MITSUBISHI Concept-RA to the world at the 2008 North American International Auto Show (NAIAS or the Detroit Motor Show). MITSUBISHI Concept-RA fuses a passion for dynamic, exciting driving with a heightened sensitivity for the environment thanks to clean, efficient high performance diesel power. The 2008 NAIAS runs from January 13 to 27 at the Cobo Center in Detroit and opens to the general public on January 19.
MITSUBISHI Concept-RA shows that thrilling performance and environmental responsibility need not be mutually exclusive concepts. This coupe concept features the S-AWC vehicle dynamics control system driveline and the Twin Clutch SST automated manual transmission used in Lancer Evolution*1, and is powered by a new high-output, high-efficiency clean diesel engine.
*1: Lancer Evolution X in Japan
The MITSUBISHI Concept-RA S-AWC driveline adds Active Steering and Active Suspension control to the ACD*2, AYC*3, Sport ABS*4 and ASC*5 component systems that comprise the system used on Lancer Evolution. S-AWC integrally manages all of these systems to realize advanced levels of control over drive torque and braking, thereby upgrading traction, cornering and vehicle stability. All this adds up to intuitive, on-demand vehicle behavior that faithfully reflects driver intent under all driving conditions, from everyday use to emergency avoidance situations.
MITSUBISHI Concept-RA is powered by a new high-efficiency, low-emissions 2.2-liter 4-cylinder DOHC 16-valve turbodiesel engine with MIVEC*6 continuously variable valve lift and timing control. With piezoelectric injector common-rail direct fuel injection that allows a lower compression ratio and with a VD (Variable Diffuser)/VG (Variable Geometry) turbocharger, the clean diesel unit delivers a maximum output of 150 kW (204 PS) and maximum torque of 420 Nm (42.8 kg-m). For compliance with U.S. emissions standards (Tier 2 Bin 5 emission regulations), the engine relies on a new catalytic converter system that brings together diesel oxidation catalyst (DOC), NOx trap catalyst (NTC) and diesel particulate filter (DPF) technologies. The new diesel engine will deliver exciting driving manners with a high degree of fuel efficiency.
For improved crashworthiness and to reduce vehicle weight MITSUBISHI Concept-RA features a new body structure using an aluminum space frame made from extruded aluminum sections and die-cast aluminum members, as well as engine hood, fenders and other outer panels made from high impact-resistance and easily recyclable plastic resin.
