2013 NISSAN Maxima – Power Moonroof
Power Moonroof (if so equipped) Your vehicle's moonroof can tilt up and down or slide open and closed. The ignition must be in the ON position to operate it. If your vehicle is equipped with a dual panel moonroof, push this switch toward the OPEN position to open both sunshades and the moonroof. Push the switch toward CLOSE, and the moonroof and both sunshades will automatically close. To tilt the moonroof UP, push the switch. To tilt DOWN, push the switch a second time. To open the moonroof, push the switch to the OPEN position. To close, push the switch towards the CLOSE position. If your vehicle is equipped with a power moonroof, push this switch to the TILT position to tilt the moonroof up. Push the switch to the OPEN position to tilt the moonroof down. To open the moonroof, push the switch to the OPEN position. Push the switch to the TILT position, to close the moonroof. To partially open or close the moonroof, push the switch in either direction while it is moving, to stop it in the desired position. Open and close the sunshade by sliding it forward or backward. When the ignition is turned OFF, power to the moonroof continues for a period of time. If either front door is opened during this period of time, power to the moonroof is cancelled.
